Figured I would post some pics of my current Taco build and the changes that will take place in the next few weeks.
Current setup:
Pioneer Amp Wired up at a 2ohm + 4ohm load in a 5 channel setup and mounted on a simple 1/8" ABS plate under the driver seat. This was pre Audio Control LC7i. The high level inputs on this amp really ****, which is why I ended up adding the LC7i.
Driver side front door with the Noico and Kicker 6.75 Coax installed. Before and after.
Kicker CompC 10" Truck wedge and one of the 6.75 coax
Current setup:
- Stock Head Unit. Entune (Non JBL) 7" touch screen. Decent unit, I see no reason to replace it and have to deal with the cost and programming for a Maestro RR.
- Audio Control LC7i line out converter. This made a HUGE difference in sound quality versus using the high level inputs on the Pioneer amp. Details in the photos.
- Pioneer GM-4704. These amps had a lot of good reviews and I wanted some good sound on a budget so I started with this amp. Currently running in a 5 speaker configuration 120w @ 2ohm for the mids and highs and 120w bridged for the sub. Crossovers set at 100Hz IIRC.
- 4 x Kicker CSC67 Coax in the doors. Again budget drivers with decent sound.
- Kicker CompC 10" 4ohm prefabbed truck box. "Bump on a Budget"
- Noico 80mil sound deadening.
