What are they worth?
  • 5
I mean look them up on
The interweb new and go from there. I think they are a good solution for someone pinched on height and not interested in a high wattage system. The output potential of that bigger woofer is good
Thanks man, I’m very pleased with em. I’ve tried several brands over the years and wasn’t expecting what they are doing on a 500.1 right now. I may sell them or just go bigger in the amp. Thanks for a normal reply tho
how many did you buy?
what type/size enclosure?
they should sound pretty good. JL is just $$$ for what you get. but they make really good stuff
I bought two, in a sealed box unfortunately with a 3000 watt amp. Of course the amp is a cheap Lanzar from what I’ve been told so I haven’t tried it, figured the subs are rated pretty low even if that amp could push the actual numbers it says
I bought two, in a sealed box unfortunately with a 3000 watt amp. Of course the amp is a cheap Lanzar from what I’ve been told so I haven’t tried it, figured the subs are rated pretty low even if that amp could push the actual numbers it says... but they only cost me $100 so 🤷🏼‍♂️ send it !
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
557
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
944
SouljazStruggle
SouljazStruggle
Ky
Bobbytwonames
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
