Running 2 speakers parallel on a mono amp helpp
Marz57
I'm trying to connect 2 kenwood full range speakers (8 ohms, 140 watts each) to a 1100 watt boss mono amp (2-4 ohms rating I believe) . I successfully added one speaker, it sounded crystal clear, amazing sound quality. I added the second one this evening, and the sound quality is still good, but not as clear. The amp is only turned up like 1/3, any higher and the bass completely over powers the front speakers and I'm trying to keep it relatively balanced 🤣
Anyway, I have it wired as a positive running from each speaker to the positive on the amp, twisting the ends together at the amp positive. Same with negative. Using 16 gauge wire. My questions are, what is my total impedance load on the amp? 16? Or 4? And if I run a single positive from speaker A to the amp, same on negative, and then run a wire from speaker A to speaker B, will I get a better sound quality or wtf? I've never done anything like this before so just making sure everything is in order. Thanks in advance.
Edit, also; there is a very slight distortion/fuzzy sound now, barely noticeable but it wasn't there with the single speaker.
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
372
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Marz57
Marz57
Fort Mill, SC
Bobbytwonames
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
