Toggle switch
Juarez60
I was wondering if putting a toggle switch in between my power wire would be fine or if it would damage something,my remote turn on wire connection doesn’t work,I figured it’d be ok since turning the toggle switch off would turn off power from battery but wanted to hear what y’all said!
It would be better to wire a pac80 in line it’s like a big relay and can be wired with a smaller wire to a toggle switch . Usually the biggest toggle switch is around 30amps .
Is the remote wire bad on the deck or the input to the amp ? If no output from the deck you can use the red accessory wire as an amp turn on .
The input to the amp doesn’t work,so does the pac 80 inline connect to the red+ power wire
Depends how your remote input failed. Is the amp on all the time or off all the time?
If the amp won't turn off, then switching your B+ lead could solve your issue. If the amp won't turn on, then switching your B+ lead won't help you.
As stated, you will likely need a relay to handle the amount of current some amps require. Switches have ratings for the amount of volts/current you can run through them.
- Joe
Something similar to this unit here but made by Parrot, I think I also had one made by Belkin also.They both worked really nice...
346
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
702
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
Juarez60
Juarez60
Beardstown,Il
jt4x4
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
