Amp going to protect even at low volume
Matt_z34
So I got a new car and put my old setup in (skar lp1000 monoblock, Jensen w12 4 ohm single coil, 4 gauge), whenever I turn up the volume slightly my amp goes to protect. Multimeter says battery isn't dropping voltage but when I check at the amp I can drop from 12 to 9.5 on a small bump, ground and all wiring is fine. Battery not discharging fast enough maybe? Would adding a second small battery help with this? Really can't figure this one out.
If you are dropping to 9.5 volts on a 1k wired to 4 ohms you have a major issue.
Bad ground
Bad battery
Bad wiring
Is there anyway I could narrow it down? I know my ground is good I checked resistance and there was basically non from the factory ground. The car was wired previously before I bought it and they left the wiring in, but I checked it all before I even put the amp in and it all worked fine. If i buy a new battery to test could u return it if that's not the problem?
If that amp isnt under warranty, you can crack it open to view the board to see if there is a loose connection on the power supply that may just need to be soldered back in place. Look to see if any Mosfets are burnt/not connected to the board or swollen caps/burnt caps ect.
Matt_z34
Matt_z34
Florida
