Right amp for Sundow Sa12D2? Skar/Kicker/Other
Big Diego 27
47
I've finally have my four door speakers(Kicker 6.75 csc67 100 rms)being powered by a 4 channel Kicker amp(Kicker 46cxa360.4, 65 rms x4). Now I am ready to add my Single Sundown Sa12d2(750 rms). Would the Kicker 46cxa800.1 mono amp or the Skar Audio RP-800.1D be a good choice? The Kicker 46cxa800.1 is 800 rms x 1 at 1 ohm and the Skar RP-800.1D is also 800 rms x 1 at 1 ohm, but the skar is over $100 cheaper.
I will pass on the Skar then, I like the Taramps, but it makes me nervous when a manufacturer only puts a max watt and not a rms watt.
A couple of good options:
not to hijack, but @denim do you have personal experience with audio legion? have you ran it?
My vote is for taramps. The little fn things are awesome
3k rms barely the size of my hand
18299
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
840
That heatsink's shape, color, and plexi bottom is just like the US Amps. I like it.
Complete novice at this so that is why I am here. Looking for guidance on what type of speakers I should be looking at getting to replace the...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Big Diego 27
Big Diego 27
2RZ-FE
    Apr 13, 2024
    Apr 13, 2024
