First ever install finished kinda 13.0v's
danielbea122
CarAudio.com Exclusive
360
42
Tampa
I couldn't have done it without this forum thanks to everyone.
18084
Looks like crap I know but I just wanted to get everything hooked up to see if I will need the HO alt
The little SQ voltage meter was staying at 13.3 - 13.5 with a/c and headlights on idling
18085
Guess I'm buying an alternator
Update after realizing the kinetik brand battery terminals do not tighten well, I had to replace them with marine terminals. Problem is that after getting a good connection my voltage dropped to 12.9-13.0 idling.
Still have to do the big 3 in the morning after car cools down completely but probably just going to order the alternator.
13v is totally fine. You have a 2nd battery and you aren't even using it until you drop below 13v. If you never plan on going above this power level, 12v+ is a-ok and spending money on an alt is not worth it. Just beat on it and if the alt dies, then replace it. A single bank of caps would do more for your voltage than an alternator (for the price).
Good job hooking the voltmeter up to the amp input terminals. Make sure you calibrate it with a DMM if it has a calibration potentiometer
Amp says it takes 14.4v for 2200w rms
Right now it's barely pushing the speakers. My single sa12 was way louder than these 2 American bass xfl 12s
Like I said just gonna buy the alternator (probably should have purchased it first)but first gotta do the big 3 to see
If that doesn't work then these soundcubed amps **** but I guessing it needs 14v
It's not loud because you're barely getting 1kw due to rise. If you want it to be louder you need to get something like the Taramps MD5k. Your box may also be the problem, on top of the trunk. You won't notice much of a difference in loudness with an alternator. That's just not how it works.
I'd sell the amp and battery, get a Taramps MD5k, and a bank or two of caps, if you want it to be audibly louder.
If you can wire to .5, get a bass 3k or bass 5k
Hmm in that case then I might buy another one of these amps for each speaker and get the alternator
These are dvc 4 ohm so I can wire to 2 ohms each I believe
You can do that too. You just won't be getting much power out of that amp after rise. Changing the orientation of your box in your trunk is another think you need to try. Or is it a suv, can't tell
XFL12's have a 3 inch coil afaik. You need a solid 1.5kw per sub to get their peak output
Err are those HD's not xfl?
It's a Toyota Corolla lol can't really move the box much. I can face the speaker towards me.
Probably should mention the speakers are brand new so after a little break in and flipping the box around I'll start giving it some gain. See how it sounds.
I gave them about 20% gain didn't wanna go to hard.
If 13v is fine I'll just watch it and leave it alone for now. Going to start looking for a bigger amp that won't need to be pushed to the max all the time.
Like I said, you aren't touching the batteries until you hit 13v, even then you're just touching surface charge. If you drop below 12v at idle then you need to start looking into more ugprades. A single bank of caps is around $200 and would keep you in the 14s on that amp imo.
Cool. That's something new to research.
Would a third battery basically do the same thing? I can get used Northstar batteries for $75 with 6month guarantee.
Not sure exactly how caps work but I thought they were there to kick in when the voltage drops too low which protects the equipment.
You'll get pretty much the same voltage drop with a third battery. It'll just hold it in the 12's better.
Caps aren't there to protect anything. They're basically a buffer for big spikes in current draw.
Finished big 3 and now it's staying 13.5v and thumpin without any fluctuations in the voltage
Cleaned up some of the ground connections as well
Thx for the help
They are very good amps. I had two of them strapped at .25 each years ago. Box rise plays a big role in how much power you are actually going to see. If you aren't dropping below 13 volts I wouldn't bother with an alternator. Buying another 2200 and running them both at 2 ohms would not be worth it. I would just get a Taramps MD8k at that point.
True but it's fine now. Im just going to keep an eye on the voltage.
It's staying at 13.5v with high beams on, a/c and 20% gain. Volume knob at about 60%
The GTP 609c cost 142 USD as well as the infinity PR6510cs. as per reviews on the net, the 609c is among the best for SQ/quality music.
14
Yeah we did that. We're stupid loud right now. Almost done just need the head unit.
60
17K
UPDATE: Guess it was the amp the whole time, not enough power for two 10” subs at 600w rms each. Bought the CT Sounds 2000w amp and voila, I now...
43
4K
find attached pics of my amps and the speakers/sub in my trunk
danielbea122
danielbea122
Tampa
danielbea122
    Apr 28, 2024
    Apr 28, 2024
