When to start worrying?
Charbel Bernaba
39
 I installed today my second amplifier the jlxd600 watts and i originally had the xd400 4 channel amplifier for my door speakers. Im running on stock alternator which is 100 amp. I checked my voltaged and it dropped from 14.6 to 13.4 and it stayed there. Is this normal? or it's time for a big alternator?
Nope. I can drop to mid 11s if I try with 6 batteries and an HO alt. Car has been 100% reliable for 8 years of beating on the electrical system.
Somebody here recommended me the stinger voltemeter. i just order it. ill get it installed when it arrives. but i heard theres 1 problem with those voltemeters they are not fast to catch a voltage drop
The Stingers work fine.
Your using your alternator. If you drop below battery resting voltage (12.5 ish) you are then using the battery and your alternator isn't keeping up.
The only problem im facing right now. Is i need somebody to install the stringer voltmeter when it gets here. i know it's easy but im that stupid when it comes to cars and electronics
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
983
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
Charbel Bernaba
Charbel Bernaba
Charbel Bernaba
    May 18, 2024
    May 16, 2024
