LEDs for exterior side steps and interior lighting?
  • 2
jeeper2269
I have a Jeep Wrangler Unlimited and want to install some LEDs (2 each side) facing down on the side steps. And some inside, maybe a couple on the floor on each side of the cab and a couple on each side of the roll bar.
Which ones are good quality you guys use ?
Almost anything on eBay for that purpose. If you want water/shockproof stuff, look for trailer lighting, as in semi truck.
Will these be durable/reliable ?
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
933
I'm going to do a wood roof tomo but I don't want a shitty looking interior like most of the ppl I see doing it. What is the best thing to use to...
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
jeeper2269
jeeper2269
Somewhere, OR
jeeper2269
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
