what size wire for door speakers 12g,14g, 16 g
  • 4
Jimg
CarAudio.com Regular
216
13
putting a set of component speakers in the doors ,  focal iss 130 component speakers,     probably going to run a 100x4 amp at 4ohm   just turn down the gain a little
putting a 2nd set of focal iss165 components with the 6 1/2 in the lower part of the door with running the tweeters somewhere on the dash
what size wire is recommended from running to the speakers from the amp
the  length of each  wire run should be around 12-14 feet from the amp in the back of the trunk to the door speakers
using ofc copper wire      is 12g overkill ,  would 14g, or 16g be just fine.
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
3K
Agreed. I've used some very fine cable for +REM connections because I had it laying around and have had issues with it failing. Good quality...
5
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Jimg
Jimg
n2audio
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
