Limiting charge current to battery with resistor
kcr357
ft laud
Putting a 1k system into a boat, will have an isolated dedicated battery for the amps and radio.  The charging system is only good for 15 amps, and some have a tendency to be finicky/fragile when excessive draw is introduced. (Mainly due to ecu failure )  what i plan on doing is using a 300ish watt .5 ohm inline resistor to limited current to the amp battery to 7.5 amps.
Anyone have input?
i honestly wouldnt put that large of a stereo in boat with weak charging capabilties.....last thing you want is to be stranded with dead battery way out in the water....(start paddling LOL)....but thats just my opinion....but than again im not too familiar with boats, but have been stranded on the water in a boat at night and it *****
Thats the reason im running an isolated battery just tor the system.
Dont think the resistor will work on second thought
The resistor will work for charging the battery, but it won't alleviate the load that you believe is killing the ECU
You need to consider the entire circuit
I'm guessing the charging system is internal to the boat engine and thus limited in size?
Yeah the charging system is a stator Magneto Magneto type some versions had an alternator but not mine. I don't believe it'll be a problem with the ECU on this engine but my friend had a different type of boat with a different computer setup and dead end up burning out his ECU. Just trying to stay on the safe side
Hmmm, taking a stab here. This assumes you can use (and own) a volt meter and can test the individual cell(s). Here is a link that might help...
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
876
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
kcr357
kcr357
ft laud
kcr357
    Jun 3, 2024
