Can I just use electrical wire instead of speaker wire?
For 4 guage 150 amp fuse is fine. If it where 0 guage then you'd need a 250.
Would it matter if I used a 250 amp fuse since it is only if something shorts out and I might plan on adding a second amp and running 1/0 to a splitter by both of them.
I thought you fuse for the total sum of the current draw? Like in the manuals it says what fuse size to use by the battery. Why would I fuse for 150 amps if my amps draw around 100 amps?
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
Joel114
CarAudio.com Recruit
Joel114
2RZ-FE
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
