Terrum 10+ year member
CarAudio.com Recruit
Hi community,
I bought a sub amp bundle for an Orion XTR-1000.1 amp and Orion XTR154D sub. Unfortunately the seller is claiming they are out of stock of the amp, so they suggested the Rockford Fosgate Prime R750-1D instead. They also offered the XTR152D sub for the lower impedance/ohms to match the amp (?)
However when I looked up the amp and it doesn't seem as powerful in RMS or even in maximum wattage. So I'm not sure if the Rockford amp is actually going to perform as well as (or better than) the Orion amp. (Orion amp is 4000w with 400w RMS on 4-ohm, and Rockford amp is unknown wattage with 500w RMS on 2-ohm)
The 152D and 154D are both 3000w if that helps.
A little help would be fantastic. Is the Rockford Fosgate Prime R750-1D better than Orion XTR-1000.1 or not? Should I go with the offer? Any other sub/amp recommendations within the £500/$650 price range?
Many thanks!
Many thanks!
