Trunk Rattle
  • 3
prestonnn
5
Texas
Hello,
I have 2 10' Kicker subs in the trunk of my 2017 Honda Civic. On certain songs, the trunk rattles and it sounds pretty bad. I placed some foam pads behind the license plate and tightened the trunk latch but none of those improved the rattle. Is there anything else I can do to improve the sound besides paying a lot for dynamat?
Thanks
Hello,
Thanks
u can use mat., easy to put on this stuff is so thick 1 layer can help, 2 be better though 250 mil thick 3-5x what most is but it's not cheap http://gpcaraudio.com/gp-stfu-v2-250mil-20-sqft-5-sheets/
look around for anything that will rattle.... jack, jack handle, spare tire/mount, trunk hinge rails, i guess thats what theyre called (under rear deck?)
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
663
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
974
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
prestonnn
prestonnn
Texas
nauc
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
