Work truck...
Beentown
Changing out my final 5 channel. This is for my work truck so staying in a budget. I have had good results with the Soundstream/PPI amps. Just starting the underseat layout. The size/power ratio on these are certainly impressive.
520.4
1000.1
520.4
1000.1
having good luck with my ppi.. how much mounting depth do u have in box? u say 1 10 or 2?
If it’s a work tuck than were is the company logo? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I am self employed and do not advertise on vehicles, for any of our businesses. It just asks for problems if an accident happens. In a "company" vehicle many more are known to grab for their neck, or even get hit more with insurance scammer claims.
Even my job trailers are not badged.
2-10's. The depth is 7" and the magnet can't be huge. 6.5" magnet or so. I want efficient subs that don't need gobs of power. I am REALLY happy with the JBL's but they are minimum impedance of 2 ohms (your favorite). Lol
May as well upgrade and use the potential of the amp (1k).
oh they're single 4 ohm? ok i'll look around
The current JBL's are wired 2 ohm. The new will need to be dual 4 ohm as I want a final 1 ohm load.
May just go SA-10s again or E3 since they are more efficient and I am running lower power. Thinking about trying the American Bass also, just to try something different. Don't think I have enough power for them though at 500 watts each.
Open to suggestions.
i wouldn't do xfl on that power and wouldn't do any other ab sub.. u want louder or sq or in between? cause at that power i'd bet sq hds 2.1 would be pretty loud and cheap (may even be on sale at Easter) but don't know how good they'll sound..
I recently bought 2 Sundown Ev3 10's from the yard sale in my fox box powered by an IA 10.1 and I'm loving it. I would recommend the E's for sure with the power you have. Yard sale is still going on too.
Nice! And that is a good reason.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
246
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Beentown
Beentown
Central, OH
Louisiana_CRX
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
