More amp tests on deck... Opinions on more amps...
bigblank69
Eureka, MO
Incase anyone is interested in what I have on deck for Amp tests. Here is what I have coming out soon
1. Soundstream PA1.5000D
2. Audiopipe APMI-1500
3. Infinity Ref-704A
4. Lanzar OPTI 700x2
5. Skar RP2000.1D (Even though BigD and I ordered at the same time, this video will be more on the Customer Service of Skar experience).
6. Precision Power Black Ice 7000.1d
7. Kicker KXM400.2
After these I am looking for thoughts... I am leaning to picking up a Tarmamps TS800x4 for the 4 channel crowd, and a Pioneer 8601 so I can get the guy who keeps asking me and Big D to test it off our backs. I'm also thinking off pulling my Orion XTR1000.4 out of my truck for a Dyno Run.
I am also thinking of a Stetsom 3KEQ. After that... I am looking for ideas... Maybe a amp that we know will likely be junk like a Pyle, Boss, SSL, Planet Audio, Power Acoustik...
I know for some of you these amps aren't exciting... but it is a "Budget Amp" YouTube channel
I have a suggestion /request for a 5 channel amp that puts out quite a bit of power and is quite affordable. I believe it will really surprise people that are looking for a 5 channel. It's not a very well known brand here in the US, but some people know about it. Lmk if you want the info of the amp and it's $299 new if you buy it online.
Lanzar Amplifier, 3,200 Watt, SMD Class A/B MOSFET, RCA Input, 2 Channel Amplifier, Amp Power Supply, Bass Boost, Mobile Audio, Amplifier for Car Speakers, Car Electronics, Crossover Network (EV294) http://
https://www.amazon.com/dp/B00BQO050E/ref=cm_sw_r_cp_api_iz4yAbQRP0A25
Pyle PLAM3601D Class D Monoblock Power Amplifier
https://www.amazon.com/dp/B002RUAVNM/ref=cm_sw_r_cp_api_UA4yAbJJV52CR
CRUNCH PX 2000.1D POWERX Amp (Monoblock Class D, 2,000 Watts max) https://www.amazon.com/dp/B01M7MDEG5/ref=cm_sw_r_cp_api_VD4yAbV098037
Power Acoustik R1 2000D Reaper Series Class D Monoblock Amp 2,000 Watts Max, 500W RMS x 1 at 4 https://www.amazon.com/dp/B00T3QBYM0/ref=cm_sw_r_cp_api_vF4yAbQF5N9TG
DS18 GEN-X3000.1 3000 Watts Max 1 Channel Class D Monblock Amplifier with Bass Remote Knob https://www.amazon.com/dp/B071DPGGYP/ref=cm_sw_r_cp_api_TG4yAbAF68RGY
Autotek 4000 Watt Mono Amplifier Class D 1 Ohm Monoblock Car Amp | MMA4000.1D https://www.amazon.com/dp/B00YSLGSGW/ref=cm_sw_r_cp_api_kI4yAbN1QEFZ2
Power Acoustik CB1-8000D 4000 Watt RMS Mono Amplifier Car Audio Class D+Amp Kit https://www.amazon.com/dp/B078WP3HFV/ref=cm_sw_r_cp_api_3I4yAb9WKN2T2
DS18 CANDY-X5SL Silver2000 Watts Max Full Range 5 Channel Class D Amplifier with Remote Subwoofer Level Controller https://www.amazon.com/dp/B06Y4CJQ5V/ref=cm_sw_r_cp_api_mK4yAb8E38VF3
Lanzar VCT2610 6,000-Watt 2-Channel High-Power Mosfet Amplifier https://www.amazon.com/dp/B002WLEY34/ref=cm_sw_r_cp_api_SK4yAbSS04PV7
DTI CAR AUDIO DTIMA22005300 Power Amplifier
https://www.amazon.com/dp/B008M9TDFO/ref=cm_sw_r_cp_api_WO4yAbGAKEQY1
Lanzar Amplifier Car Audio, 4,000 Watt, 6 Channel, 2 Ohm, Bridgeable 4 Ohm, MOSFET, RCA Input, Bass Boost, Mobile Audio, Amplifier for Car Speakers, Car Electronics, Wireless Bluetooth (HTG668BT) https://www.amazon.com/dp/B00LJX5IMM/ref=cm_sw_r_cp_api_rY4yAbD4V9C79
Sorry I got a little carried away lol
Lanzar Amplifier, 3,200 Watt, SMD Class A/B MOSFET, RCA Input, 2 Channel Amplifier, Amp Power Supply, Bass Boost, Mobile Audio, Amplifier for Car Speakers, Car Electronics, Crossover Network (EV294) http://https://www.amazon.com/dp/B00BQO050E/ref=cm_sw_r_cp_api_iz4yAbQRP0A25
lol. I've seen a lot of those amps. That DTI though lol, claims 1k rms on the 5th sub channel. I heard a little about the candy amps and if you ignore the Peak watts the actual rms output seems legit.
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
557
Thanks. That makes sense. It sounds pretty good as is.
860
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Ill check it out. I was actually on the site last week. Thanks!
205
bigblank69
bigblank69
Eureka, MO
PPI_GUY
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
