Speaker questions
  • 2
rutledj
I want to upgrade my ram 1500 reg cab pu speakers. I have a 5 channel alpine amp and have ordered a slim 10" sub to go behind the seat.
I've already replaced the dash tweeters with a infinity combo mid\tweeter 3.5" combination. This improved the sound tremendously, even before the amp and sub.
My question involves the front door and rear speakers (mounted behind the seat in the side columns, so the face toward the center of the truck).
The stock speakers are 6x9s.
In replacing these do you go with a combo speaker that has a tweeter combined with a woofer (as that is all that seems to be available)?
And is the already installed cap bass blocker on the dash tweeters ok to leave in? Any other suggestions?
Thanks,
Rut
most peeps put coax like u are talking about in rear some use componets in front (we don't care much about back speakers, were call them rear fill)... u can leave dash tweets there if u want, u can run them off the hu leave bass blockers there or add them to the front 2 channels of the amp with door speaker those 2 channels will be running at 2 ohm..
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
Not saying it can't be done or will necessarily sound bad and have heard reliable sources say they've had it sound good. I just never sat in one...
True but at those prices, nickel plated copper or brass would be a much better option for speakers, no point in using stainless steel at all...
24
340
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
229
rutledj
rutledj
Reidsville,NC
BOOMINGRANDPA
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
