American bass xfl 12
  • 4
i seen that amp on SMD dynod, does very well. powerful enough to push 2 of those subs.
Ive personally never ran that sub, but it seems that all good 12's fall in the range of 1.75 cu ft - 2.25cu ft.
the tuning vs power applied is also going to effect box size.
Tuning is going to depend on what you listen to. rock/metal? rap/djslowfets? etc..
ok then, as jerm said above, id tune low. 32hz. itll help keep woofer control on very low hz songs.
my current setup is 2 sa-12s tuned to 33hz. the song rack city from DJslowfets seems to make my subs angry.. have to turn down the gain..(bass knob 1/4 turn)
i have a 3rd sa 12 now, and new box plans for 29hz
id go big on the port(16" square inch per cube net) as ive read youll run into trouble sooner with too small vs too big. So 2.5 cu ft would be 40sq in of cross sectional area
Thanks guys I'll take all this into consideration will post finished product middle of next week... But one last question I bought one already and have the opportunity to buy three more for 300 is that a good deal
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
I have 2 of them in around 2.5 cubes per sub, tuned to around low 30s Hz. I think.its tuned a little low. Really low frequencies hit thick and...
4
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
861
Alphaqupgood
Alphaqupgood
Hartford wi
Alphaqupgood
winkychevelle
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
