2006 Evo 9 Build
dvcevoblack
Teh BasTehsss
722
CA
Base on this post http://www.caraudio.com/forums/general-discussion/614921-what-should-i-do-next-poll.html
I will go option 1 with MX.
Now some goodies:
Stringer 250amp Circuit breaker and Distribution block
MB Quart amp for front speaker only
Battery relocate kit with 1 gauge wiring
Now the build:
Using cardboard as a draft
Ready to cut
Ring cutout
Masking for resin
ready to put resin on.
After 3 days of waiting, It was still sticky and it never dried. Found out it was a bad resin that was sitting in the garage for little over year and half. FU*K.
So solution, Put another trash bag over the bad resin and start over.
Once the new resin dry. You can see the old resin is sticky as ***. (Click image to see video)
Drew black line to cut off the surrounding.
Exciting! I'll be posting up the build log for my 2014 evo X in a couple weeks time. Waiting for some stuff to come in the mail and for some time to set aside
Nice, Let me know once you do!
How much do you think it cost you to do the fiberglass (supplies not tools)? I've never tried it myself but want too.
Depends How much cloths, resin, etc you buy. It was under $100 when I did this.
Ever thought about ported it with an aero?
Nah, It's a SQ set up, car show looks.
Time to install Battery relocated kit.
Going to put it on left side due right side has Windshield Washer Fluid Tank.
Finish look
Any updates or pics of the car? I had a white RS but alllllllways wanted "Blue By You" //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, sorry was busy lately ha.
What amp rack looks like.
Screw the box down
Battery hookup
2 gauge wire connect to post where battery use to be
Cut off extra screw
Finish
Time to install these.
Volt, Water and Oil Temp by Prosport
SoundStream Equalizer
Goodbye Headunit
$21 for this sh*t
Connected to amps
Other end connected to Equalizer
Finish, Equalizer is in glove box & I'm using tablet Venue 8 7840 as my Headunit
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
dvcevoblack
Teh BasTehsss
dvcevoblack
CA
Dimestore55
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
