Wooden Alternator
  • 4
It's a little big to fit under the hood and you need to underdrive it about 100:1 just to spin it slow enough so it doesn't explode and send magnets flying in all directions, charging voltage is insufficient as well as charge current, 10 amps just isn't going to cut it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
wow what an asss.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
694
I don't have one...but I check my voltage with a dmm once a week or so
765
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
981
The Camry
Hey, I Try.
The Camry
Western Oregon
big scott
    May 10, 2024
3toneEYZ
    May 10, 2024
