how to save wireing
brafferty
so im about to re run my wires through my 03 outback, and am curious if anyone can give m,e advice so i don't have to run sooo much wire. I will be running 3 pairs of RCA from HU to amps in the back, and 1 REM from the HU to one amp, and a smaller REM from one amp to the other. but what im really concerned about is running these 8 wires for my speakers from the amp to the HU, i was just going to do the usual run from the engine through the side trim and to the back, but that requires a lot of wire, any help or do i just gotta go with it? oh and of coaurse the Power wires for the amp
you dont run rca and speaker wire to amp. pick one or the other.but rca is best.
wait what?! did my "mentor" teach me wrong?! ive never heard that and im a noob still, been buildinjg for me and friends almost a year
What brafferty means is he's running RCAs from the HU to the amps, and then the amplified signal back to behind the headunit, and he's connecting those wires to the factory vehicle harness that is routed to the door speakers. Much easier then running the wires directly to each of the doors, although not as efficient as the factory wires are usually very cheap and thin.
If you want to shorten your runs, only thing I can suggest is do what I did (if its possible in your vehicle), put the speaker amp or amps under your front seats. Then the runs are much much shorter. Makes sense since your signal and power source, as is where you're sending the amplified signal, are all in the front of the vehicle.
if thats what your talking about then ok.
the way you said it was you wanted to run both speaker and rcas TO AMP.
but if your talking from the amp to your speakers then ya
you have to be more clear.
my bad, i thought it was pretty clear haha
brafferty
brafferty
idaho
brafferty
BP1Fanatic
BP1Fanatic
