The right subs
I have a crew cab chevy and I want to put two subs under the seat. I was lookin at the Kicker 40cwrt121 shallow mounts but I've been gettin mixed reviews on them. What are se good subs that would sound good in my truck at a reasonable price?
What's your budget and how much room do you have? Shallow mounts are pricey.
$500 is the highest I want to spend. If I can put regular subs under the seat I would. I see they have a seat bracket to move the seat forward maybe I can put behind the seat. I'll get the dimensions
Iwould suggest the Sundown SD-3's if there out if not the SD-2. They only need like 5" mounting depth. I Ran 2 10'sinmyMini and it was plenty so in a truck more than enough.Stillmay have to raise the seat very little. You can get 2 of them for under $300 not including box.
I'm running one 8" sd-2 in a .4 cubic foot sealed fiberglass box. I'm very impressed with it. Sounds like I have a 12" back there. They're a little pricey, but you'll love it.
No to that option man. Weak overpriced sub that cant play lows for crap.
Three times the sub that kicker can ever be, here are the reigning Kings of R&D:
Sundown Audio SD-2 12" D4 500 Watt Dual 4 Ohm SD Series. Build a downfire box and pair it with a 750 watt amp.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
870
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
4K
Stanb23003
Stanb23003
Columbia, MS
mclerico83
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
