The right subs
If you get 2 of the sd12's you will have to go sealed. You go that route get the d4's wire them to one ohm and you will have a lot more affordable amp options. You don't have the space available to do two of the ported even with a seat lift.
I'd I was to get the sd-2 12 would I need to get one or two? Would I get the 2ohm or 4ohm and what kind of amp
i would get two if you want some decent output. as far as ohms go, it depends on what amp you want. most of the time you would want a pair of dual 4 ohm for a 1 ohm load on a mono amp.
Stanb23003
Stanb23003
Columbia, MS
mclerico83
