AndrewHD 10+ year member
Hey guys I installed 2 Sundown SA 12's in my Impala a while ago and it is not as impressive as it should be. Box is custom made by Buck 4.0 cu ft net at 31hz powered by a Rockford 2500.1 at 4 ohms. I think it may be due to a low pre amp voltage on my Eclipse AVN 726e (5V preamp). Does anyone know how to test pre amps and where would I put the black and red probes from the multimeter? A picture or video would help so much. I have heard that this unit needs to have the volume up to the max and sub setting maxed out to get 5 volts so I am skeptical at this point
