6.5" Enclosure Build Help
  • 1
bradl79
NLR
i was looking at a sealed box for my 6.5 Exodus Anarchy
Re: 6.4 Ohm
Le: 0.84mH
Fs: 45.8Hz
Qms: 6.37
Qes: 0.48
Qts: 0.44
Mmd: 29.4
Mms: 30.25
Cms: 0.4mm/N
Vas: 9.61L
Sd: 131 cm^2
BL 10.79 N/A
SPL: 84.7 dB/1W/1m
Pmax: 125W
Xmax: 12 mm 30% Down Point on simulated BL curve
VC former: 34.95mm Kapton
VC: Wire: round CCAW OD0.25mm with EISV, 4 layers, winding width 11.0mm
Gap Height: XBL^2 16mm tall with 5mm gap to form 2-plates: See Drawing
Power Handling: 125W Approx: No AES or IEC power testing conducted
can i get some measurements and for what would be good for this, i need to make a box for 2 or should should i do them seperate boxes, thank you.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
595
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
3K
bradl79
bradl79
NLR
bradl79
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
