6.5" Enclosure Build Help
bradl79
i was looking at a sealed box for my 6.5 Exodus Anarchy
Re: 6.4 Ohm
Le: 0.84mH
Fs: 45.8Hz
Qms: 6.37
Qes: 0.48
Qts: 0.44
Mmd: 29.4
Mms: 30.25
Cms: 0.4mm/N
Vas: 9.61L
Sd: 131 cm^2
BL 10.79 N/A
SPL: 84.7 dB/1W/1m
Pmax: 125W
Xmax: 12 mm 30% Down Point on simulated BL curve
VC former: 34.95mm Kapton
VC: Wire: round CCAW OD0.25mm with EISV, 4 layers, winding width 11.0mm
Gap Height: XBL^2 16mm tall with 5mm gap to form 2-plates: See Drawing
Power Handling: 125W Approx: No AES or IEC power testing conducted
can i get some measurements and for what would be good for this, i need to make a box for 2 or should should i do them seperate boxes, thank you.
bradl79
bradl79
NLR
bradl79
