High- Low Frequency & Low- Low Frequency?
  • 5
Enemy5802
So I have my new system set up. It sounds great! One problem though, when I play music, those "low beats" hit pretty hard. But when it comes to those high lows they are kinda weak.
Is there anyway I can mess with the amplifier or lpf settings to even them out?
*I will check back in tomorrow hopefully I get some help:)
That will depend upon the sub and enclosure as well... What are you running? IE: HU, Speakers, Amp(s), Sub(s) Enclosure Type, Size & Tuning If Ported???
It's a ported 12' 300w rms subwoofer enclosure tuned to 32-35 hz. Running at 2ohms. Connected to an aftermarket head unit.
Mmmh, amp is also being rated at 300 rms. Anything else? Lol Oh and it's a Kenwood mp245.
Set the LPF frequency on your amp to like 80-100hz-ish, NO BASS BOOST if your amp has it, and adjust your gain accordingly... Whatever your results: are all that particular setup is going to play...
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
458
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
You need to set the high pass filter for your 6.5" speakers. I wouldn't run anything lower than 80hz. 100hz would be alot safer. Adding a...
4
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
482
Enemy5802
Enemy5802
United States
Enemy5802
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
