6" or 8" port? (two 12" type Rs)
  • 4
moparerrnocar
Fargo, ND
Im trying to decide if I should do a 6 or an 8...
The box is 23x36x12 going in a 97 grand prix with only 1500 rms. Being as I don't know what frequency I like most since I have such a diverse taste in music, my plan is to build the biggest box I can and then experiment with different length aeros. I'll probably be making my own from pvc.Originally my plan was to make two 6" ports that adjust 2" (coupler), one 12-10 (32-34hz), and the other 8-6 (36-39hz).
The 6" gives me 6" per foot, will this be enough? 8 gives me 11.5"-12" per foot. Only issue with the 8" is it has to be twice the length and requires a 90 and a lot of volume and wouldn't be as easily adjustable. The 8" would have to be 28-23 (32-34hz) and 19-15 (36-39hz), in terms of adjustability that range won't be possible w/o making 3-4 ports. I realize I can just keep cutting it shorter, but Id like to be able to go back and forth to see the difference. The second concern is volume, the 6" nets me 4.5-4.7 (12"-6") but the 8 nets me 3.9-4.3.
My goal for this box is to increase my efficiency w/ added output. Currently running 3^3 @ 42hz w/ 11.5 per foot. Its way too boomy and horribly inefficient, I get some pretty bad voltage drop with my diehard platinum agm bat and 0awg and factory 105amp alt. I planed to upgrade to an ho alt, but Im hoping a new box will reach the mechanical limits b4 current limits.
How much difference will 1/2 cube and 6" of port area make? What's better for my intentions, big box small area or slightly smaller box with twice the area, and why?
Thanks
Sorry for such a long post btw....
Looking at Alpine's optimum box specs - looks like they recommend 1.3 cubes of airspace per woofer, with 15 square inches of port.
They also rate the power handling at 500 watts RMS per woofer.
Based on the numbers you've given - you'd have about 2.07 cubes of airspace per woofer (net) and ~750 watts of potential power per woofer.
Overpowering woofers in an oversized box is going to be a recipe for disaster.
I'd bring your box size down, and use a single 6" aeroport.
Yeah,... Anyone with experience care to help.
No offense N8scow, but you clearly have no experience or knowledge with type Rs. Firstly, I never mentioned the gen or model so you just assumed they where the 3rd gen or older (2010-older). I have the 4th gen 600rms (2011). Type Rs are always way under rated. They are well known to take 1000rms daily. The new 5th gen handle 1000rms and are basically the same woofer mechanicaly. Secondly, type Rs like 2-2.5 cubes. You can argue, but alpine (like most popular manufactures) spec their subs for a wide range of vehicles and listeners thus the small box and high frequency. Ftr, type Rs take beating, I've been clipping the **** out of mine w/ dirty power for two years running. They still sound great, but begging for more power and or efficiency.
You didn't list what subs you have specifically - so I took a guess. My bad...
At any rate, good luck with your build.
If you're not chasing numbers, a 6" with a good flare would be fine with those subs. You might gain 1dB with an 8" depending on box design, but you wouldn't hear a difference. I'd bet money on it.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
906
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
615
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
773
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
747
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
moparerrnocar
moparerrnocar
Fargo, ND
brandon_s0854
Latest topics
