Which amp will need more power from my alt and battery?
  • 4
If you only going to use the amp on those speakers...I would go with the 70x4..
If your going to do 2 ohm stereo. ...same amp...it will put out more power and you got 2 channels left over.
11
522
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
916
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
wesburnsco86
wesburnsco86
Kings Mountain,N.C.
mclerico83
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
