power handling in relation to box size
  • 4
borntorun
if i increase the size of the ported box...larger than the manufactures size...by 2 or 3 times, how will this affect the speaker if im still providing it the suggested rms.
example:
suggested enclosure: 2 cubes @ 36hz
suggested power handling: 1200wrms
actual enclosure: 6 cubes @ 36hz
actual power handling: 1200wrms
will this overpower the sub, and blow it; or will it underpower it, and i just wont get the subs full potential?
the more air space there is, the less power required to get it to reach full excursion but it'll sound like doody, get the enclosure big enough and you get into IB/free-air setups
if the recommended size for a ported box is 1.5cuFt, would 1.75 and 2.0 really mess stuff up?
well i wouldn't think so, it'd lower the power handling for sure, would probably make it have a slower response too
Does anyone have an idea how much (the most) these comps can happily handle?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
452
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
355
borntorun
borntorun
mansfield, tx
Acidburn
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
