does polyfill make a noticable difference?
sorry, but im confused?? what do you mean by 1 pound per cubic foot? is that how much i need to put in there to make a difference in the sound? and what exactly does it make a difference with, i heard it makes the box sound like its "bigger", is this true? any help would be appreciated thanks
Mike
It tricks the driver into thinking there is more available air space than what there actually is. And, yes 1lb per cube is what to use, if your box is 2.5 cubes you use 2.5lbs.
its not really that the sub thinks the box is bigger....it changes the acoustical properties of the enclosure.
when you stuff any box full of fiberous material it slows the backwave. in doing so, you create better low-end frequency response. the amount the backwave is slowed is directly proportional to the amount of stuffing used. If your box sounds like crap below 40hz, pack that sucker full. if it gets a little response but not quite enough, just use the suggested 1lb/cuft.
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
103
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
805
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
854
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
infinity1412
infinity1412
ocala fl
Omarvelous
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
