$15 for (10) 2/0 Terminals
  • 7
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
I cannot keep track of all the forums I am on, so please email me at Ryan@RAM-Designs.com with your PayPal address so I can send a PayPal request to you.
(10) 2/0 ring terminals
-tin plated to resist corrosion
-fits 2/0 welding wire or over-sized 1/0 CA wire
-3/8" bolt hole
-access hole in front to feed solder into for a superior connection strength
10 = $15 shipped
20 = $25 shipped
30 = $35 shipped
etc.
Included in price.
Hey Ryan I bought some database batts from you last year local we met up at AMC firewheel, I need some of these bad, when can we meet up? I need 10. My number is 972-800-5544,
Thanks
Jeff
Fuck I just realized this is for 2/0. Not 1/0. Mhmm... Wonder how it would fit on my wire
Too big for 1/0?
These fit over-sized CA wire just fine without trimming. If you have some good wire that is obviously bigger than 1/0 welding wire, you will have to trim it to fit 1/0 terminals, since the guys making these terminals simply follow the AWG guidelines for cross-sectional area, which is what welding wire follows as well. The car audio folks tend to overdo it and make the wire bigger than 1/0, which is why 2/0 ring terminals work better.
[quote name='akheathen']@RAM_Designs; i don't really do the e-mail thing. i want 10 to try out.... also, is this a normal thing to be selling these? bigger available? i might be interested in a bunch of 4/0 for up at work.[/QUOTE]
I do not have ant 4/0, but i have quite a few of these 2/0 ones that fit over-sized CA wire nicely. I have my PM's turned off, so the only way to contact me is via email or the chat feature here, if you don't want your email to be posted on the forum.
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
6
687
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
9
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
