running a stock head unit with amp and subwoofer
  • 2
2ndroundko
Ok I have done a couple installs with aftermarket radios and that's no problem. My question is what do I run the RCAs to and where do i get my remote wire from. The vehicle is a Saturn L300 the reason I want to use the stock unit is it has stock components mids and tweeters and I dont want to mess up the speakers by removing cross over. Can I use my aftermarket head unit and properly control the speakers.
So you want to use the stock head unit or you aftermarket head unit? lol
For stock unit your RCAs go into a line converter, audio shops and websites have them. Your remote wire will be to be ran from the battery or anything else that has a 12V supply. You will need to install a switch (get at autozone) unless you tap into the cig lighter or something that only works when you turn the key on.
for an aftermarket head unit you could just tap into the speakers power wires before the crossover so you dont have to mess with them. that would work fine
see I WANT to run hu but I'm not sure where the crossovers are in the car
hahaha you have to have a HU, the stock one or an aftermarket?
Im assuming you want to run the aftermarket HU, like i said tap into the power wires before the crossover with your amps power wires. Google where you cars crossovers are
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
338
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
4
2ndroundko
2ndroundko
Greenville NC
2ndroundko
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
