Northeast Region whats a good high speaker brand to use?
CT,DC,DE,MA,MD,NH,NJ,NY,PA,RI,VT,WV
It depends if you're talkin spl or sq...because for the price, they do hit hard...they just sound like total @ss defecation.
Most of the stuff on the "high end" section is accurate, which is what he is looking for...
prob run the front off the dack and the back off a jl audio 300.4
money?? idk
if there good and all ill save for them lol
That amp should be fine to run the front and rear speakers. If you had to choose running the front or the rears off the amp then you'd really want to run the fronts off the amp. Those need to be louder since the fronts are your main speakers, your rears are just for some fill.
that amp should be fine to run the front and rear speakers. If you had to choose running the front or the rears off the amp then you'd really want to run the fronts off the amp. Those need to be louder since the fronts are your main speakers, your rears are just for some fill.
true>>>
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
894
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
ecac06
ecac06
ct
Louisiana_CRX
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
