Northwest Region 1st Comp in Colorado 2010.
AK,CO,ID,MT,ND,OR,SD,WY,WA
sub-FATHER
Resurecting this sport
1,620
denver, CO.
so whats the earliest you guys are willing to show up for a show? and who all is gonna have something to compete with this year.
i would like to do something a little different this year. and have a couple of events where we have three stages of the competition.
1.)outlaw burp score
2.)Bassrace score ( closest to 29.9,39.9 ,49.9) without going over
3.)drive by score
least amount of points wins. the goal is to end up with the least amount.
points will be given for the bass race section, if you get it on the dot you receive 1 point, if you miss it by 2=2 points etc...
if you go over at any point you automatically get 5 =points
you will receive 1 point for highest spl in your class
you will receive 1 point for highest drive by in your class
your drive by score will be subtracted from your burp score, and the person with the smallest difference will get 1 point, 2nd = 2 point etc... in your class.
you can hit higher numbers when the air temp is cold //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well its like below zero here and i'm sure no one wants to do any in winter.
Windows would be shattering...
well its like below zero here and i'm sure no one wants to do any in winter. Windows would be shattering...
Only time i shattered my windshield was when it was this cold //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Sounds like too much math and confusing ****.
its actually simple. lowest total numbers win. chances of a tie are slim, but gives people that are not the loudest in their class to have a chance due to the bass race section, and the diffence between the spl and drive by score. you could win the spl and the drive by but go over in the bass race and be 5 points down and loose. its actaully quite simple.
that would make some cool you tube videos....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and I thought it was cold at 50 outside today //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
the math is for the judges and this accomidates everyone in your class,
if you cant bassrace and control your volume then you end up with extra unwanted points.
if you decide to sandbag in the spl section so your driveby isnt that far off, (which is a strategy in this set up) then you will have the smallest difference between the two numbers.
however you wont have to be the loudest in your class to win, this opens the door for more chances of winning other than the guys who have the money and rediculous systems that are guaranteed to put up big numbers
this will also prevent people from showing up with a box for burping only, everyone will have to be able to play music
this will be just like learning a new board game. all the other orginizations didnt just start without glitches, but this will end up being easier than it looks at first
highest spl = 1, points
2nd place = 2, etc
highest drive by =1 point
2nd place = 2 etc...
smallest difference
from the two scores =1 point
2nd place =2 etc...
bass race points off
or desired goal 139.9
149.9, 129.9 ,= 1 point
off by 1 (139.8) = 2 point etc
go over at all = 5 points
the winner of each devision,
1 sub = lowest points when all are added together
2 sub= " "
3+ sub= " "
bassrace was created for shows to be fair i think.
this sport needs to advance or its gonna get boring, the only way to advance it, is to make it more competitive since the competitors are so diversified in their system make up. as it is now the people with the most money win! thats crap!!!
only way around that is to out smart them...
yeah that works but makes it one way either way. either you build your system to burp at 60hz and not musical at all or spend an ass ton of money to have an azz ton of subs and amps an batts and wire etc...
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
673
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
920
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
sub-FATHER
sub-FATHER
denver, CO.
csu87
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
