Will caulk/sealer fix this problem?
Solo-baric
Newbie
191
Minnesota
I built a box for my 10" kicker cvx and it sounds great. Ported to about 35Hertz and being pushed by a kicker amp. But..............my wiring terminal lets a little air through. Can I open up my box and put some clear caulking over it to block the air off? It is a spring-style terminal just to let you guys know.
Dont even open the box, just pop the terminal itself, and put some caulk around the inside of the rim that screws to the box, and screw it back down
I was thinking about doing this, but some air is coming through the wire holes themselves and I can hear it sometimes. Maybe around the edges and on the back of it, might as well just put it right over where the wire connects on the inside I guess?
When ever you build another box just run your wires straight into the box. Drill a hole about 1/16th of an inch larger than the wire, run it it into the box and seal the hole from the inside.
So tonight I took the terminal cap out and reconnected my wires to the back of it alot better and sealed itup with electrical tape and some caulking, the sound is all gone:)
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
So a hard-reset seemed to reduce the frequency of the issue, but it didn't go away. In fact, I can re-create it repeatably by going through...
Solo-baric
Newbie
Solo-baric
Minnesota
geowick07
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
