Zx @ 1 ohm?
no 1 ohm.
K, thats what i figured just didnt know if i could for a short time without hurting the amp. Now i gotta decide either to run the zx @ 4 ohms or to run my shitty Visonik 1802 on them till i get a new amp.
I wired my friends 750.1 to 1 ohm and havent had any problems.
I am sure it depends on box rise, and the actual reading of the coils. I had 750.1, and mono channel of 700.5 both wired at 1 ohm with my backup sub and both went into protect multiple times with Big 3, Optima up front and batcap 800 in the rear. So it depends on amp and setup individually.
what kinda power will the 750.1 do at 1 ohm? the birthsheet on mine was 936 at 2 ohms...so i was told ...
It is wired to 2 dual 4 ohm CVRs so I used a DMM to get it to 800W. Wont push it any farther since it isnt rated as a 1 ohm amp. Dont want to fry it.
i tried running my zx2500.1 at 1 ohm..my electrical couldnt back it up though.
Ya a 2500.1 is going to take a lot more electrical to be able to run that at 1 ohm. Lord knows what it would put out //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
My zx2500 did fine at 1ohm.
To the OP youll be fine at 1ohm. Kicker amps are beast. Just keep your voltage up which shouldnt be hard with on 400w. Id say atleast get a kinetik 2400 and youll be golden //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mythyone
mythyone
Greenbay, WI
inkfx
