pwnt by pat
Pat for Prez 2024 - vote!
I've been doing some reading and zobel filters has caught my attention.
A little intro:
In normal crossovers, caps, resistors, and inductors are used to filter out unwanted frequencies. However, a woofer by itself is an inductor. Due to the nature of inductors, the higher the application frequency, the higher the resistance.
This is where zobel circuit come in to play. The zobel network uses a resistor and capacitor based on the woofers re and le values.
On the other end of the spectrum, the large impedeance peak apparent at the speakers fs also causes crossovers to be inaccurate and less effective. This is supplimented with a series notch filter, also using a cap, resistor, and adding an inductor.
Now, in active circuits, the crossover happens prior to amplification. In doing so, any post-amplification crossover is eliminated, thus the removal of the zobel circuit and series notch filters.
The benefits of both circuits is obvious, as the natural resistance of the woofer can be almost completely elminated, allowing for more efficient use of the amplifiers power.
Now to my questions:
1) In crossover construction, the notch filters are applied after the crossover circuit (further from the source). Would the zobel circuit be closer or further away from the source than the series notch filter? My assumption would be as close to the source as possible?
2) Is it possible to apply a zobel circuit and series notch filter to a driver post-amplification using an active application while having no or minimal adverse effect to the post-amplification crossover?
edit: quick links:
http://www.carstereo.com/help/Articles.cfm?id=36
http://www.carstereo.com/help/Articles.cfm?id=23
A little intro:
edit: quick links:
