Zapco REF1000.4 help
BlackMaxima
LA
Zapco REF1000.4
4-channel, 4 ohms: 4x150 Watts
4-channel, 2 ohms: 4x250 Watts
I wanna use the 2ohms 4x250
I want to use 1 & 2 Channels for the front comps
I wanna know if i can use 3 & 4 Channels to power a pair of 12inch IDQ'a in a IB set up
Keep in mind this amp are underrated in power
well with that amp you can give the fronts 125x2 and if you wire the woofers series/parallel it will give them 500x1.. so in short yes it will work.. i want that amp so i can run 2 es6s and drt26s active.. I'm jelious
you mean to say give the fronts 250x2 @ 2ohms
BlackMaxima
BlackMaxima
LA
BlackMaxima
