Ap30001d
djarmy2004
djarmy2004
Does anyone have any problems with the AP30001D going into protect under extreme loads. If it hits notes to hard or for to long it shuts down. Could this possibly be a RCA voltage issue? Im using an Alpine CDA-7998 as HU. I have no voltage drops as when system is full tilt w/ AC on the lowest the voltage goes is 12.3
Yeah same here..my voltage doesnt really drop but it will go to protect on heavy bass hits on 1 ohm. my volt meter reads high 13's to low 14s when im driving and it will still go to protect at 1 ohm.
i thought they are only 2 ohm stable. 1 ohm with a very good electrical.
You have 2 c&d batts though. try to run it at a higher load or swap amps
yeah they say its only 2 ohm but i think you can get away with 1 ohm if you have the electrical to back it up. I just dont know how much you need lol. if you arent doing it with 2 c&ds in the back and big 3 im not going to bother on trying to beef up electrical for it for 1 ohm
which leads me to believe they should not be ran at 1 ohm. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I dont know how much more i can put in it, i have the big 3 done twice, 260A DC Power Alt, Interstate Batt up front and 2 C&D in back with everything running full tilt i get above 12.4 and at idle i get 14.2
I dont think it will hurt it cause it will just go to protect on you, but yeah.
and it still goes to protect @ 1 ohm on heavy bass?
djarmy2004
djarmy2004
djarmy2004
Hopkinsville, KY
mgcauctions09
