Sold zapco ref 500.1
now with pics, let me know if you want to see anything else.
hahahaha, to the lucky person that buys it, i'll include what's left of the shirt note pad. =) that is if you really want it. but make some offers, need to sell. worst i can say is to low, how bout $$$.
from the web site
Mono, 4 ohms: 1 x 360 Watts
Mono, 2 ohms: 1 x 500 Watts
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate: >29V/uS
Damping Factor: >250 @ 4 ohms
Dimensions: 12"L x7.5"W x 2"H
if you really think of it, this would make a good sq sub amp. if not, and if you don't mind running mono, you can use this as a front speaker amp and each speaker will be seeing a little over 250w rms. if you decide to run all 4 speakers to this amp, each speaker will see about 90 w rms each. if all speakers are 2 ohm, then that brings it up to about 125w rms each. so it could be a good sq sub amp or even a good speaker amp. maybe even a good starter amp for your subs and then if you need more sub out put, buy a bigger sub amp and use this for your speakers. the possibilities are endless.
justlooking
justlooking
honolulu, HI
justlooking
michigan born
    May 14, 2026
michigan born
    May 14, 2026
