gentlejax 10+ year member
Item(s) for Sale:ZAPCO AG650
Item(s) Description/Conditionretty good shape. I havnt taken top off to see inside but I can .
I have no amps in car and this would make a easy install instead of multiple amps but I just dont feel like doing a total install from scratch. car is new and has stock wiring.
specs:
50x6 @ 4 ohms
100x6 @ 2 ohms
sub channels only 180x2 @ 1 ohm or 360x1 @ 2ohm mono.
The amp has a built in 3 way crossover which is infinitely adjustable from 55-5500hz on each set of outputs. channels 1 and 2 only can be set as highpass, lowpass, and bandpass. All other channels can be set as high or low. Has 3 sets of balanced mini-din as well as rca inputs. Seperate input gain for each set of outputs. Can be configured to run off of one, two, or all three sets of inputs ( you don't need a deck with 3 sets of rca preouts). Has built in fan cooling as well as a huge heatsink;
amp measures 32" x 7.5" x 2.5"!! It is meant to run an active 3 way system consisting of tweets, mids, and subs. It is also perfect for competition 151-300 watt power class.
link to manual
http://beyondtheboxdesign.net/limomo.../pdf/ag650.pdf
Price:$325 shipped in USA
specs:
50x6 @ 4 ohms
100x6 @ 2 ohms
link to manual
