Your Worst Install Fiasco
mapolley07
its all imaginary
I know there was a thread on this a while back, but its long-dead. I just had a fiasco last night, so i thought i'd bring in a thread revival.
Well last night My buddy and i decided to start working on installing his sub in his Audi A4 and we couldn't find a good place to run the power wire through the firewall. I looked online and everybody said to find a plugged hole in the firewall and drill through any plastic behind it and run the wire through there. Well, we found a nice big spot behind the battery and we looked at it and couldn't foresee any problem drilling thru the plastic in that hole.
As soon as I got the drill going, i started to see what looked like steam or smoke coming out around the drill bit. I just figured that the plastic was burning a little bit from the drill, so i stopped and pulled the drill back out, and then A/C coolant started blowing up through the hole i drilled and down through the bottom of the dashboard and began to fog up the whole garage. It was not good
cliffs: drilled through and air conditioner line when trying to run power wire
unless the power wire was as big a fist the there are a few places to run it. well at least when i did my moms s4 (same car different motor). should have gone on a audi fourm and looked it up.
but my worst. installing a amp late at night on my friends mustang. getting 2 12s to fit in the trunk was a huge *****. well i toutched the power to ground. scared the **** out of me and make me jump back.... cutting the back of my head on this metal lip inside the trunk..... hurt and made a little mess. also a little trip to the hospital.
fyi if your ever trying to install an amp and the car is not a stick you can almost always use the clutchstamp. (where the clutch would go)
But that sucks and wont be cheap, but look on the brightside you did get a hole in the firewall
fyi if your ever trying to install an amp and the car is not a stick you can almost always use the clutchstamp. (where the clutch would go)But that sucks and wont be cheap, but look on the brightside you did get a hole in the firewall
daaaaaaaaaamn, you got a ton of deadening/dampening crap goin into your car ha
lol that is what is in there, more will be going in, have some rammatt and some extreme i would like to put to use
reminds me i need to update whatever that is called
Did my first radio install on my old car, unhooked the battery(to be safe //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif). Got the harness hooked up, battery on, car fried. Left all the wires exposed and touching //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
****, i feel better about myself now lol.
yeah, we looked on an audi forum and on here and couldn't find any pics, so we just guessed at a grommet. found several with just plastic behind them and figured this one was safe to drill through. apparently not, lol
never had a problem with any other cars, but they were all american cars with more room to work and more predictable layouts.
i guess you live and learn
mapolley07
its all imaginary
mapolley07
Georgetown College, KY
ultimate157
