luckily we havent paid for it yet so i can still give it back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so i have that going for mepretty much, mine was sitting around for like 6 months before i installed too, and i only paid $50 for it so i just chucked it as a lost
i'll hook it up tomorrow and see how its doingi suggest you grab a battery load tester and see how it does by itself hooked up to nothing... i mean if it hisses thats a pretty darn good tell tale sign to ditch the b!tch!
i did actually let it charge for about an hour prior to installing itwell if it was sitting for a while, and was down to 11 volts, It may just need to charge. Throw a 2 amp trickle on it overnight and see if it helps.
And the wise cracks,
Maybe you have xover on the battery set to high?
Loose ground.
Are U running the RCAs next to it?
what a queer, someone hit it with too much juicewell if it was sitting for a while, and was down to 11 volts, It may just need to charge. Throw a 2 amp trickle on it overnight and see if it helps.
Loose ground.
it came straight from the store. unless they charge them in there?someonelse did, the batt wasnt brand new
