Y spiltter connection... HELP!!!
deserte4gle
my HU have only 2 preout which i already connected to woofer's and mid's amps..
Forget about the electronic crossover or preamp as i dont have budget to get it....
My question is, can i connect another amp using 1 male 2 female Y splitter cables or vice versa?? can i connect the Y spiltter from the tweeter's n mid's amp and pull the rca from the HU??......like in this picture... http://www.bcae1.com/ycable.htm
In other words i want to play 3 amps but my HU preout is limited which is only 2 preout....
yes,, one male to two female would work fine
how about 2 male 1 female as picture above.... is it ok??? if i use 1 male 2 female i need to have 2 pair of rca cables from the amp as im out of budget right now..... got side effect using 2 male 1 female cable???
monoprice.com is your friend. They have every type of splitter, adapter and short RCA cable on the cheap with reasonable shipping.
nvm bro... i can get the splitter easily in my country....thanks by the way...
my ques is it ok if i use 1 female to 2 male cables for my setup???
if the rca's will reach the right holes its fine.one rca ran back to a female to dual male splitter will work.
so it seems that ive no prob to connect it coz my 2 amps just beside each other as i believe that the rca from the HU will connect the Y splitter perfectly...
by the way, im using HU pioneer 3050UB with 3 band EQ...... the setting for the tweeter is limited which have frequencies 3khz,8khz,10khz,12khz and Q factor 1N,2N,1W,2W... furthermore, my 2 channel tweeter amp doesnt have HPF setting but my HU got HPF setting which i believe it is for the component ONLY..... am i rite??? or the HPF setting at my HU is for the both tweeter n mid???
deserte4gle
deserte4gle
MALAYSIA
deserte4gle
BP1Fanatic
BP1Fanatic
