XXX spl numbers>?
TooLowTooGo
2Low2Go
1,472
Jersey
ive been asking alot of questions lately, sorry. lol.
but i went to a comp last weekend and i saw a RE XXX 15 only pull a 134. i didnt get to take pics but she said she had 2000watts going to it. i noticed it was sealed, but even if it were ported with the 3db rule it would be aroun 137. kinda low. maybe the box was built wrong or somethin.
soooooo n e one that has a XXX please hit me up wit some numbers to make me wanna get these things:)
thanks
Friend of mine hit at 144 with 1600 watts ported. He accidently had the bass turned most of the way down on the H/u also.
thanks
What type of vehicle was this in? It can make a pretty big difference.
man thats weak, i have my hc 15 in a sealed box with 1500rms goin to it and i got 134. yeah crappy i know but it was in a box that is 2.sumthing.
it was in a corola. im pretty sure.
my goal is to hit 155. i would love to bring home one of those BIG ass trophies. so thats y i was plannin on doin 2 XXX's n aroun 8000watts but if i see ppl hittin like low 140's it aint gonna be worth gettin 2 of em then n spendin money on maybe high 140's.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
It is NOT the subs, it's the INSTALL.
If you want some big trophies, you can HAVE my dust collectors (aka - trophies)
Trophies are overrated - $$$ prizes are where it's at! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
btw - good luck on the 155 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1 reason im hopin so high is because i went to the last comp, the mic wasnt setup up right so i should of hit alittle higher but i got a 144.4 with 4 12" MTX 7500's in a crx style box tuned to 45hz with a power acoustik a3000db amp. all wired to 2ohms so 1800watts. but with the voltage drop it was prolly less. i have a stock alt n only 4guage wire.
im plannin on runnin about 4000 to each sub n upgrading my alt, wires, n maybe some extra batteries. so thats y im hoping do high. plus i would love to have a bigger trophy than 28".
To jump 10 dB is a big task. I hit 144.4 with 3 JL 12W0's and 350 RMS in a sealed box on the AC. I'm only at 151.4 now on the AC with 2000 watts, and 2 15's. That 151.4 on the AC is more like 145 on the TL, so it's a long way to go from 155.
I'm not saying you can't do it, and good luck with it, I personally just hate being let down, so I'd shoot a bit lower and then when you actually hit the 155 you'll be more impressed //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good luck,
Craig G
1 reason im hopin so high is because i went to the last comp, the mic wasnt setup up right so i should of hit alittle higher but i got a 144.4 with 4 12" MTX 7500's in a crx style box tuned to 45hz with a power acoustik a3000db amp. all wired to 2ohms so 1800watts. but with the voltage drop it was prolly less. i have a stock alt n only 4guage wire.im plannin on runnin about 4000 to each sub n upgrading my alt, wires, n maybe some extra batteries. so thats y im hoping do high. plus i would love to have a bigger trophy than 28".
If you're only using 4 ga wire on 1800 watts, you're in danger of a seriously burnt wire or fire.
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
TooLowTooGo
2Low2Go
TooLowTooGo
Jersey
XDrkmanX
    May 19, 2024
    May 18, 2024
