JimJ
Tangled Up in Blue
Easier to bypass it and run it off the head unit or external processing...**** I wish the Tantrum had 24 db xover slopes.
problem is I run an epicenter which needs a full range signal. sucks too since my head unit does 36dB slopes. don't want to spend the money on an external processor either.Easier to bypass it and run it off the head unit or external processing...
true but the diff between 1200 watts and 1400 watts is like 1/3 of a dB of output. Not much to care about.tantrum. the xenon is really not more flexible. generally if you can wire your subs at 1 ohm, you can wire them at 4 ohms. also there was a bad batch of xenon's, plus they generally benched at 1200 watts at 4 ohms vs. 1400+ watts at 4 ohms like the tantrum.
The xenon is the superior amp, doenst put out as much power, but it has more features. For his needs though, the tantrum should work just fine. As for the xenons and their failures, that problem was long fixed, and more than likely the reason you still hear about xenons breaking is because their are still bad ones out. Thats why you buy it authorized. Ive ran my xenon for 1.5 years now, and its been running great. Either way you look at it, your getting great amps. Just flip a coin.my point was the tantrum is as flexible as the xenon, so why not spend the money on something that'll do more power, instead of spending more money on something that would do less power, that had a history of failures //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Somehow I knew you would chime in on this.The dual power supplies alone should tell you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The xenon 1200.1 had dual power supplies. Page 10 shoud tell you everything you need to knowplease elaborate. which has dual PS and what advantage is it?
