Xenon 1200.1 vs. Tantrum 1200.1
hmm i thought tantrum was a/b and xenon is D. can't you run the x1200.1 at 4 ohms too? anywho, i like the xenon better.
The Xenon is a class d and is more flexible for sub's(1200x1@1-4 ohms). The Tantrum is alot smaller and IMO looks alot bettter. It puts it power out at 4 ohms.
The tantrum would probably be cheaper.....I got mine off here for like 250 a while back.
i like the xenon cause they are a bit more efficient; ~80 percent. however, the tantrum puts out a bit more power but at ~70 percent efficiency.
I'd take the Xenon for it's felxability and it is more effiecent like jacka said......but I'd be real tempted at the Tantrum because its so small and looks 10x better. The tatrum will give you 1400+, I'm not sure about the Xenon but it would definatley be more than 1200.
It all depends.. Although the xenon is much more flexible, the tantrum is smaller, draws far less current, and puts out more power. Its a toss up //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yea, i think my xenon sucks quite a bit of juice, especially on a tiny elec like mine
Old school?
It's hardly that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd choose the Tantrum...wait, I did //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Old school?
like i said. if you can call it that. i had a tantrum before. fried it on my mistake. was perfect power at all 3 loads for my 3 different setups. but i moved to bigger things. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
tantrum. the xenon is really not more flexible. generally if you can wire your subs at 1 ohm, you can wire them at 4 ohms. also there was a bad batch of xenon's, plus they generally benched at 1200 watts at 4 ohms vs. 1400+ watts at 4 ohms like the tantrum.
ghart999
ghart999
Denver, CO
DWancha
