Xbox Sound
_MstANg_
My headunit is an alpine 9811. it has the subwoofer ourputs and then a 2 left and right rca outputs. Im wanting to put an xbox in my truck with a flip down monitor from the ceiling. I dont think my HU has an aux. output so how could i the sound to play from the system? Would i have to buy a new HU?
buy an fm modulator, run the rcas from xbox to it, then it has a plug that goes to your antenna plug. Thats what I have for my PS2 in my stang with stock HU.
First you want RCA inputs, outputs are called preouts, you have those. You can also probably buy the aux adapter for your hu, then you can just use that, but if that isn't possible use the fm mod as a last resort.
so if i buy the aux adapter will it automatically over ride a CD or the radio when the xbox starts or will the aux adapter have some sort of switch?
its a function on the deck, atleast it is on the Pioneer decks. u have to select it like you would radio or cd mode, after the aux is plugged into the deck.
they aux adapter will not over ride anything. it will only add another source to your hu. so when you want to use xbox, you simple press the source button until aux is selected.
one downsize, u wont be able to use a cd changer if u have it. the alpine, most of them, use the cd-changer input as an auxiliary too, you just gotta buy the special adapter that converts the cd-changer input to rca inputs.
yeah I would want to do this last, just mentioned because you said it had no imputs.
that sounds good, i dont have a cd changer anyways, since it plays mp3 i just put about 5 cds on one disc. but i was looking on ebay and typed in aux adapter.. the Pioneer CD-RB20 seams to be the main option, running at around 40 dollers. It will work with my alpine, correct?
_MstANg_
_MstANg_
Glasgow, KY
_MstANg_
