I'll answer this question the best I can as I understand what your trying to ask. First off, I don't think the Orion uses XBL^2, but for the sake of understanding/arguement since XBL^2 designs do use small coils, I'll answer anyway lol.
First thing to realize the major benefit of XBL^2 is what is usually referred to as a flat or linear BL curve. BL is a measurement of motor force. It's generally measureed in tesla meters, but can also be measured in newtons/ampere. Newtons is a measurement of force and amphere is a measurment of current through the wire. Basically, the more BL product you have, the more acceleration you'll get on the cone for the same current flowing through the coil. A non optimized sub has this value drop as excursion increases and the coil leaves the gap. As it's get's further away you get less push since your further away from the center of the field. This means your effeciency drops since lower BL means you'll need more power to make up for the lack of motor force at that new distance away from the center of the gap. An XBL^2 design doesn't have that weakness. A good design like the new Tempest X has almost a perfectly flat BL curve to over 20mm. Most woofers (even expensive underground ones on here) realistically begin to lose motor force from 10mm onward. Another advantage to XBL^2 over an overhung is that since you can use a smaller assembly due to the shorter coil, you can often use a smaller gap and have less coil rub. Air is a bad conducter of heat so a tighter gap without worrying about coil rub means you can get the coil very close to the motor where the heat can actually get into another piece of steel. The Acoustic Elegance woofers (non XBL^2, but a good example of a tight gap) use a very tight gap and can actually rate their woofers conseratively at 1000 watts RMS, even with just a 2.5" coil. Just something else to think about.
Anyway, the dropping of the BL as the coil moves means those drivers generally need more power than the non XBL^2 version. Since they become less effecient as they move, you need to keep dumping power onto the coil to increase excursion. A XBL^2 woofer that is properly built won't do that. It'll be as effecient at 1mm of excursion going to 2 as it is from 10 going to 20. Because of this you need less coil since it will need less power to reach it's mechanical limits. Ultimately that is what makes a speaker loud. How much BL you can fit under a curve, not how much power it takes to get you there. It's just like a dyno for a car, power under the curve is what counts. That's why SPL designers shoot for as much BL/RE as they can get, higher BL values mean more acceleration so greater SPL's as they displace more air near tuning.
Also, since someone else mentioned the characteristics of an XBL^2 driver, I'll relate those in as well. The smooth almost dry sound is lack of distortion. Any BL variance with stroke will show up as non linear distortion, this is common in loudspeakers so it sounds strange when it's not there to some. The lack of boomy sound as the volume increases that most subs have is also due to a flat BL curve. If you look at how the T/S parameters are derived, if BL decreases the speakers QTS (electrical Q value) will increase. This increase in electrical Q increases the overall Q of the system. This is what changes when you put a speaker into a smaller box vs a bigger one, smaller boxes have higher q's, bigger boxes have lower. So as the BL drops on a regular speaker, the overall Q goes up and you lose some of your low end bass. A XBL^2 won't do that, it sounds the same as volume increases, it just gets louder.
Anyway the issue most older XBL^2 designs had playing up high was due to inductance and inductance variation over stroke. Modern designs that use faraday rings like the tempest X or even the SSA Xcon shouldn't have that problem. Actually, since the coil on an XBL design is smaller, inductance should be lower. The XXX's were notorious for this problem as they used a fairly big coil and didnt' design the motor well in that regard, the brahmas were usually characterized as a bit punchier, they had less inductance I'd assume.
Lastly, the thing to remember when using an XBL^2 design for a "street beater" is this. They will always be thermally limited. As I said earlier, they are effecient so they can reach XMAX fairly easily and give you lots of clean output for lower power overall. However, an XBL^2 design's BL beyond xmax, drops VERY fast. This limits the excursion you can get beyond it's clean limits. In the real world this means you'll notice that if you turn the volume up you'l find it gains SPL pretty linearly and cleanly. At some point, possibly sooner than your used to do the effeciency, it simply stops getting louder, all at once. This means you've reached the clean mechanical limits. If you keep adding power, yeah, it will heat up the coils, however, since BL is dropping at a very fast rate, that's alot of power that isn't doing much to move the cone, there is very little force being given to it for all that extra power. Because the cone isn't moving beyond xmax easily, you'll also notice it doesn't sound bad or strained. The woofer basically refuses to go much past XMAX so if you get stupid and just crank the gains you'll just blow it with no warning signs as unlike most subs, it won't bottom itself out or sound like dog poo with the Q dropping cutting off your low end. In short, once you notice it stops getting louder, dont' push it expecting anything else, it's not there your just risking damaging it.
